drill accesaries
Old 04-11-04, 07:03 AM
drill accesaries
Are there any drill motor accesseries to use it as a hammer drill. I only have a couple of small small masonary screws to put in. The bit I bought says to use a hammer drill. My regular drill motor dose not work that well for this.
Old 04-11-04, 07:10 AM
Dave_D1945's Avatar
I've seen hammer drills that can work either way, but I don't know of any gizmos that make a regular drill into a hammer drill.
Why not rent a hammer drill for an hour?
Old 04-11-04, 06:44 PM
GregH's Avatar
Super Moderator
Received 13 Votes on 13 Posts
Woodwright:
What size hole are you trying to drill?
A 1/4" hole for a small anchor might be dooable with a standard drill but much more and you will need a hammer drill.
If you were to start with a really small hole like maybe 3/16" and work your way up it may work with a regular drill.
One thing that sets a hammer drill apart from a regular drill is that a small hammer drill turns at much a faster rpm than a regular drill.
I have a small Makita that turns at 3000 rpm on high speed.
Most drills max out at 1200 rpm.
