Phuematic nailer
Old 05-07-04, 08:37 PM
blackhawk505
Phuematic nailer
Im wanting to buy a general purpose nailer anyone have any ideas what would be a good one to have,Maybe used for some light framing and stuff like base boards and such.Any help would be appreciated.James.
Old 05-08-04, 08:31 AM
GregH's Avatar
Super Moderator
James,
There is really no one nailer for all jobs.
There are brad nailers that shoot light guage brads up to two inches long.
Finish nailers that have a heavier guage nail up to two and a half inches long and framing nailers that have a heavier nail up to usually three and a half inches long.
A brad nailer is often the first nailer a person gets because of their low cost and their suitability for moldings and trim.
Old 05-08-04, 08:14 PM
I'd go with any of the combo units -- the ones with a compressor and brad nailer. The nailer is usually 18 gauge and only handles 1.5" nails. You can then add a 16 gauge nailer that will use up to 2.5" nails.
For your use, you probably want a smaller gauge nailer for framing, and then a larger one for things like baseboards where you want more holding power.
If you already have a compressor, then most nailers will do the job for light duty work. I personally have the Sears combo and added a 2.5" when I was putting on baseboard in a remodeling project. I haven't had any problems with it. Porter Cable and others offer packages at the big box stores, and any one should be OK.
I have both a nailer that is oiless and one that needs oil -- I prefer the oiless one, less hassle. Compressors that are oiless are noisier then one that need oil and are usually considered better (also more expensive).
