Craftsman beltsander
Old 06-29-04, 10:33 AM
majakdragon's Avatar
I was given a Craftsman 4x36 inch belt sander with the 6 inch sanding disk on the side. Works great but the belt finally gave out and I have no idea how to release the assemblyto change belts. I know it releases to be able to use it vertically. Thanks in advance.
Old 06-29-04, 10:34 PM
GregH's Avatar
Super Moderator
Received 18 Votes on 18 Posts
majakdragon,
Are you referring to the sanding belt?
I have one that is not Craftsman. It has a lever between the two sides of the belt that swings out to relieve the tension.
What is the model of your sander?
Old 06-30-04, 09:36 AM
I found the culprit bolt to loosen the belt tower. It is on the drive belt cover. I thought this was just for securing the cover to the base but if you loosen the allenbolt you can raise the 36'' belt assembly from flat to vertical position. When flat, you cannot change the belt as the 6'' disk is in the way.Thanks for answering my post
