Bench Saw vs. Table Saw?
The bench saw is designed for portablity and small footprint with smaller table top. The table saw has a larger, heavier top and more stability. I provides better cuts as a result.
If you're using the saw at different locations, the bench saw is your likely choice. Otherwise, go with the table saw. You won't be sorry for the upgrade.
Thunder
Thunder
