another air compressor ?
Old 08-04-04, 06:25 AM
tbear
i have a older sanborn air compressor that has no cfm rating on the info plate is there a way to determine what cfm rating is either through testing or formulas it has psi ,hp and volume of tank on tag. sorry i don't have them with me right now i can post back with later if needed thanks for any help couldn't find info on this on sticky or any other posts
Old 08-06-04, 01:11 PM
piston size, stroke length and rpm
If you can get those 3 it'll be a cinch to figure out the displacement cfm. I suspect there are air flow gages out there if you need accurate readings at various pressures.
Old 08-06-04, 07:13 PM
GregH's Avatar
Super Moderator
tbear,
What would be usefull is the information on the motor such as hp, volts, rpm and amps.
Any numbers on the body of the compressor pump. There usually is a casting number or such to be able to identify the head.
Finally the outside diameter of the pulleys on the motor and compressor head.
