Circular Saw is Squealing - Why?
Old 08-08-04, 05:37 PM
stompeers
Hello there,
I was cutting up some board with a circular saw, and it started to squeal. It was off and on at first, but over the next couple minutes of cutting it starting doing it constantly.
When I take my finger off the trigger, the saw stops quickly, like it's not spinning freely anymore.
It's an older hand-me-down Skil saw, but hasn't had any problems so far.
I took the blade off, just to see, and the same thing still happens with no blade.
Any ideas?
Thank you,
Chris S.
Old 08-08-04, 05:47 PM
I was gonna say wood binding...but you took the blade off and it STILL did it??? ....the type of saw, and type of motor would help...roller bearings?...brushes?...etc.
Old 08-20-04, 07:56 AM
Dave_D1945's Avatar
Sounds like the bearings are going. Unless it's an expensive higher-end saw, I would junk it and buy a new one. Fixing an old one is probably more expensive than replacing it.
Old 08-20-04, 10:23 AM
GregH's Avatar
Super Moderator
I would agree that it sounds like the bearings.
If you want to play around and are handy you could do some exploratory surgery to see if a couple of drops of oil will help.
Maybe if they are sleeve bearings and are gummed up you could squeeze a few more years out of it by cleaning it up and re-oiling.
If you oil it you must use oil for electric motors, not regular motor oil, wd-40 or regular 3 in 1 oil.
You can get oil specifically designed for motors or a more economical way is to purchase a bottle of 30 weight non-detergent oil which should be available at auto supply stores.
Having an old saw repaired would not likely pay.
