Amps vs Horsepower
Old 01-03-05, 08:42 AM
Amps vs Horsepower
Every time I go look at tools I always see two different ratings Amps and Horsepower. I always thought that the more Amps a tool had, the stronger or more powerful a tool would be. What is the difference between the two and which is more important to look at?
Old 01-03-05, 11:33 AM
1 hp = 745 watts on a single phase AC
And you can get watts by multiplying the line voltage by the tool's specified amp rating. Thus, a tool rated at 15 amps on 120 volt circuit, will have about 2.5 hp
Old 01-03-05, 01:53 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
HI Hawks and Markiz,
- That's an intersting point Hawks raises about which is more important. Markiz, a great answer. I always check the amps first, as this is the easiest indication of how powerful it really is.
Old 01-04-05, 05:53 AM
Yes, Hawks, for what it's worth, definitely check the amps first. Horsepower is often given as a peak value, which is misleading, a gimmick to sell a tool. I have a shop vac that draws 11 amps, yet is rated at 6 hp peak. How is that possible?? Well, maybe if you tried to purposely stall the motor, it would generate 6 hp while drawing more current, but this will never happen in real life because it'll trip the breaker first. Well, you see what I'm getting at: running amps is what really counts.
Old 01-05-05, 07:44 AM
Amp vs HP
Thanks for your help. This gives me a better understanding for my tool buying.
