Cutting holes 1/2 way through a board.
Old 04-03-05, 07:07 PM
bvs
I need something that will cleanly bore a 1.5 inch hole 1/2 way through a board.
My first thought was to use a hole saw, but that would cut a nice outline, but leave the wood inside the hole. Is there any kind of bit or tool that would cut that hole and gouge out the wood?
Old 04-03-05, 07:20 PM
majakdragon's Avatar
I believe what your looking for is a Forsner bit. You could probably use a spade bit but the point may be a little long, depending on how thick the wood is.
Good luck with your project.
Old 04-03-05, 07:35 PM
Lugnut's Avatar
That is also the size of the 38mm hinge bit. It is a forsTner bit too.
Last edited by Lugnut; 04-04-05 at 08:09 AM. Reason: CORRECTED SPELLING OF FORSTNER.
Old 04-04-05, 07:12 AM
I thought it was called a forstner bit
Old 04-04-05, 07:18 AM
txdiyguy's Avatar
If you want to see what one looks like and you're Googling, you'll need to spell it "forstner".
Old 04-04-05, 07:21 AM
I give up. The word is spelled FORSTNER. If you say it quickly the people at the home center or hardwares will know exactly what you need .
Good luck on your project.
Old 04-04-05, 08:07 AM
Lugnut's Avatar
I plead innoccent!
I did originally spell it correctly, but seeing majakdragon's spelling, I changed it just before posting. I'm innocent I tell ya, I was no where near the keyboard when it happened!
Old 04-04-05, 10:59 AM
txdiyguy's Avatar
At the Home Depot's where I shop, you are more likely to get a blank stare if you ask for a Forstner bit (or most anything else, for that matter). Once, when I needed a new drain valve for my compressor, I asked a female employee for a petcock and almost got slapped.
