Running a flexable hose straight from the compressor
Old 04-13-05, 08:36 PM
Sawdustguy
Currently, in my shop I was blessed with having the previous renters black pipe the shop for the air lines. I'm moving to a new shop that doesn't have air lines.
In a refinishing shop, friends of mine, have a regular compressor hose run from the main 60 gal, 5hp compressor, to the different stations in the shop.
Is that a risky/dumb thing to do? I can't afford to black pipe the air lines around the shop and I'm also renting, so I obviously don't want to put tons of costs into it.
I also saw a shop where the person ran PVC pipe around and had disconnects at each station.
I also have a 60 gal 5hp Ingersol Rand compressor that I'd be doing this with.
Old 04-13-05, 09:17 PM
First, do not use pvc. It can rupture possibly causing injury. As to flex hose, I have a hook on the wall to wind up the hose hooked to the compressor. I have considered getting a hose reel, but anything but a high dollar one is a big PIA. If you don't like hose laying on the floor, consider routing a couple of 25' hoses to workstations. Then if you move, they're easy to take with you.
Mike
Old 04-13-05, 09:20 PM
GregH's Avatar
Super Moderator
Sawdustguy,
No problem at all running hose to different parts of the shop.
Using PVC though is very bad news, it can burst without warning.
Old 04-13-05, 09:26 PM
Sawdustguy
I will need to have a little black pipe done because I have an Ingersol Rand Air Dryer for the air lines and that's black piped to the compressor. I guess I could run a disconnect from the blackpipe to different stations. The shop will be 1,500 sq ft.
It's a pretty square shop too. That part I really like.
Old 04-13-05, 09:38 PM
GregH's Avatar
Super Moderator
The air drier does not need to be connected with black pipe.
You could use a short length of hose on it as well.
You could likely have a piece of 1/2" hose made up and use a swivel connector on one end.
Old 04-13-05, 09:42 PM
Sawdustguy
The top of the air dryer has in and out ports for black pipe to go into.
Old 04-14-05, 05:49 AM
I don't know what size the ports are, but I'm sure a hardware store will have pipe bushings and unions to connect hose to dryer.
Mike
