Cordless drill...
Cordless drill...
Not even sure if this is the right forum. Sorry if its not, but I have a really stupid question.
I use my boyfriends black and decker cordless drill for drilling holes in craft wood, I need to change the bit to a larger size, can someone tell me how to take the bit out and put another one in?
Laugh at me, I deserve it!
Brachypelmic,
I believe the drill you are using does not need a "chuck" or "key" to loosen the end for bit removal. You probabaly can loosen hold on the bit by twisting the nose of the drill (end near bit). Use both hands and unscrew like a jar. Otherwise, with larger drills there may be a key or chuck snapped onto the drill somewhere that will be needed to remove the bit. It will fit into a hole on the nose of the drill and need to be turned counterclockwise to loosen the bit. Hope that wasn't too confusing.
Good luck,
Countrymac
Good luck,
Countrymac
Originally Posted by countrymac
Brachypelmic,
Good luck,
Countrymac
Good luck,
Countrymac
