craftsman parts?
Old 05-04-05, 05:45 PM
buddylee03
craftsman parts?
i have a 3 gal craftsman compressor model #921153100 it has a broken fan blade that mounts on the end of the motor shaft. i looked and found a parts break down but it is not showing the fan as a part. i called sears and they said it is not available. does anyone know where i might find such a part?
thanks
Old 05-04-05, 08:39 PM
ampz's Avatar
I had the same problem with a 25 yr old Craftsman mower last year.I tried to get the switch assembly for it but it was unavailable.But the mowers that Craftsman sold new {same models this year} had a different deck & blade set-up but still used the same switch assembly.I suggest you look at compressors of the same size to see if you can get the fan blade.If not try Grainger Indust.Supply or MSC they stock parts for all different types of compressors.Dont forget to bring a sample when you go
Old 05-04-05, 09:21 PM
GregH's Avatar
Super Moderator
buddylee03,
In order to find an alternate supplier you need to find out who made that unit.
I have a list that shows a 919 product number as made by DeVilbiss but I can't see the product number 921.
I found the Sears pars list but you are right that it doesn't show a fan.
Maybe the Sears parts person will tell you who made it.
Old 05-12-05, 08:33 PM
buddylee03
i have tried evywhere but no luck. they still are selling this unit so buyer beware. i acn't belive no one from Sears can tell me where i can get this part.
Old 05-12-05, 08:41 PM
GregH's Avatar
Super Moderator
I think Sears might be able to supply you with info but you can't ask them "where to buy the part" if they already said they can't supply it..
You have to find out who the manufacturer is.
If you are persistant they will pass you on to someone who can tell you.
Once you know the manufacturer you will find out who at least might have the part.
Keep in mind that Sears doesn't make even one product themselves.
Old 05-13-05, 03:43 AM
Look at the links,
Drawing shows a Fan that maybe the same ??
Or maybe its the company that made your pump.
http://www.harborfreight.com/manuals...8999/38898.PDF
http://www.harborfreight.com/manuals...5999/45214.pdf
