Need machine to sand concrete.
Old 05-28-05, 12:36 PM
Is there a belt sander for concrete like there is for wood?
I need to level off some concrete and figure something like this would work well.
Old 05-28-05, 09:08 PM
I used a 4-1/2" 90 deg hand grinder.
You would need to get a masonry cutting wheel, about $7.00
The metal cutting wheels don't work well on stone.
Old 05-28-05, 10:00 PM
XSleeper's Avatar
You can rent concrete grinders. They are more like a grinder than a sander. If you have a large area to do, this would be your best bet. If it's just a small hump, or a small area, GWIZ's suggestion would be fine. An actual concrete grinder will give you a better finish, however.
