Need machine to sand concrete.
Is there a belt sander for concrete like there is for wood?
I need to level off some concrete and figure something like this would work well.
You can rent concrete grinders. They are more like a grinder than a sander. If you have a large area to do, this would be your best bet. If it's just a small hump, or a small area, GWIZ's suggestion would be fine. An actual concrete grinder will give you a better finish, however.
