Cut steel with recip saw
I need to cut some steel fencing down. The rails are about 1/8" x 2". Should I cut with the blade flat on the 2" side or straight down the 1/8" side? Should the blade be flat against the metal or at an angle? Sawing motion or just hold the blade in one spot?
You should cut the 1/8" edge.
Place the foot firmly against the 2" side to prevent the saw from bouncing.
I would
Cut it from the 1/8 side.
Keep the blade at a comfortable angle.
Not use sawing motion, that's the saw's job.
There are really no rules (except safety, of course) when using a demolition tool. It's not like appearance will matter
Just do what gives you best results fast.
Place the blade at least a 45-degree angle to the metal surface, if not 90-degrees. You want to cut the cross-section of the rail. I find that the blade cuts faster when applied this way.
