drilling into glass
Old 09-01-05, 02:22 PM
F
drilling into glass
hi,
i wasnt sure where to post this, but i was wondering if it is possible to drill a small hole into a glass bottle without it breaking.
Old 09-01-05, 02:37 PM
majakdragon's Avatar
Received 1 Vote on 1 Post
It is possible to drill a hole in glass. They make a bit for this. It looks like a masonary bit (drill with an insert at the end). You should use putty to form a dam around where you want to drill and fill it with rubbing alcohol and a little salt. This cools the bit and adds an abrasive. There is always the chance that you will hit a void in the glass and it will break or shatter. Wear eye and body protection while doing this. Good luck.
Old 09-05-05, 10:56 AM
walkendadoghome
They also make glass blowing torches which will heat the glass back up to melting temp and allow you to reshape it.
Old 09-20-05, 01:09 PM
F
IT WORKED PERFECTLY!! THANK YOU.
