Craftsman air compressor leaking
Old 10-30-05, 04:30 AM
jctrabue
I have a Craftsman permanently lubricated portable air compressor model number 919.165380 which just recently started leaking air through a pin hole in the head. I assume that this pin hole is manufactured into the head for some reason so what could of gone wrong to cause it to start leaking air. Could a faulty check valve be causing this problem or is there some other part that could be causing the air leak. This air compressor is less than 2 years old and out of warranty.
Last edited by jctrabue; 10-30-05 at 05:39 AM. Reason: Think may have found the problem.
Old 10-30-05, 01:52 PM
Can you post a pic? it would help us out a great deal
thanks
Jim
Old 12-01-05, 03:10 PM
mej317
Air Compressor Sear 919.165380
I too have the same model and a leak just started. I pulled the head off and also found a pin hole. What was your solution?
Thanks,
Old 12-01-05, 04:46 PM
GregH's Avatar
Super Moderator
A hole in the diaphram can only be fixed by replacing it.
