Removing rust and paint with Angle Grinder
Old 12-28-05, 10:53 PM
E
I am rebuilding a badly rusted mower deck. Now that I have it apart, I need to remove the rust and old paint. I acquired a 10 amp 4.5 inch Dewalt angle grinder to do the job but I am uncertain about which accessories to use. I have looked at cups with crimped or knotted wire and wheels with the same, sanding pads, sanding flappers and a paint stripping pad(Stotch Brite on Steriods)
I can't remove too much metal since some of the rust pockets are fairly deep. I want to avoid needing to do welding on the deck.
Any recommendations which to use?
Old 12-29-05, 02:14 AM
Use the knotted cup brush along with a good pair of safety glasses, face shield would be better.
Mike
Old 12-29-05, 06:15 AM
IBM5081's Avatar
The wire wheel will throw wires at you. Protect your neck and any other exposed skin.
If the deck is that thin, see if you can find a better deck under a trashed motor. Save the grinding time.
Old 12-29-05, 06:54 AM
Received 626 Votes on 553 Posts
I agree. You can often get an old non working mower for free or next to nothing. Just be sure the motor will fit. 25 yrs ago I put a long shaft motor on a short shaft frame/deck, had to raise the motor with plywood, lower the wheels and cut the grass short.
Old 12-29-05, 09:02 AM
E
Thanks for the thought on the wire cup versus the wheel. I read on the web that angle grinders are very dangerous so anything I can do to reduce the risk is great. I think a full face shield is in my future.
About the mower deck,
It is a 1976 John Deere 300 garden tractor with a 48 mower that I am restoring so there isn't to many extra decks avaiable
Old 12-29-05, 10:37 AM
I wondered why you chose to repair instead of replace, now we know
Old 12-29-05, 05:04 PM
Received 1 Vote on 1 Post
I use wire wheels (go for the quality ones-you'll get less loose wires in your arm that way),and a few different types of 3M wheels (they've got some new ones that work great)...and also a grinding wheel (for the tough stuff), used with care, for rust removal
Sounds like you might want to check out Eastwood Co.'s Rust Encapuslator
I usually remove as much rust as I can before using it, but I have used it for years in places/situations where I couldn't
It works very well over rusty parts
