Pressure washer
Pressure washer
Can anyone recommend a good electric pressure washer for normal outside use (cleaning of deck, cement, siding, car) for a good price? If so, name model, price, and PSI.
All the experience I have had with electric pressure washers is the pressure. Some of the ones I have seen and used only produced about 1300 lbs of pressure. That's ok, but a gasoline powered unit puts out upwards to 2600 lbs of pressure, or enough to clean a deck, degrease an engine, etc. The pressure of the electric ones don't measure up.
The electric ones are barely adequate
I have seen them claim 1600psi, which is not enough anyway, but the actual use told a different story, and not a good one
It will be a long and tedious deck cleaning process, unless you just need a little more pressure than the hose
Any tenacious mold or mildew on the siding or cement won't be affected by an electric-not enough PSI
Good for car washing though
Or maybe a one story house that's pretty clean anyway, no mold or stains or anything (1300PSI won't reach the second story with any power)
I'd recommend a gas powered PW of at least 2200 PSI
Have used both. The low price ones emit a very low volume of water at a very high pressure. It takes a painfully long time to clean large projects with this low volume technique. I reckon it's akin to a dental water jet cleaner for your teeth. Same idea, high pressure, very low volume. Try cleaning your sink with that, lol.
The high price ones, (gas models, etc) emit a large volume of water at a high pressure. It will clean large projects fast and efforlessly.
I have a Karcher 1600psi model. about $140. Iv'e used it on my one story vinyl sided home,two decks,patio bricks,lawn furniture, and my vehicles.
Does fine for me,but i haven't a gas one to compare it to.
For basic homeowner use i think it great
Personally I prefer gas, not just for the added power but I don't think water and electricity play well together - how well do you trust a GFI?
I have never had problems with any equipment that was stored for a long period PROVIDED it was put up properly.
