Circular saw blades for use w/ Rotozip w/ ZipMate?
Received 0 Votes
I'm looking for a circular saw blade for use cutting wood with a RotoZip with a ZipMate attachment. That is, blade size = 3 3/8 - 3 1/2, 10 mm or 3/8 arbor. Fine tooth prefered.
Can anyone suggest a source?
I found one once at HomeDepot, so I know they exist. Unfortunately, I can't currently find one at either my local HD, nor at HomeDepot.com. (I've also tried a web search, but am not having success so far.)
Any suggestions would be greatly appreciated.
FL Guy, Welcome to the DIY Forums.
I have included a picture of what I think you are looking for. It is HD's site. I would have the store order it or buy it online. Good luck.
http://www.homedepot.com/prel80/HDUS....jsp?pn=152822
Received 0 Votes
Hi, and thanks for the suggestion.
Unfortunately, the blade of the referenced item is only 1 1/4" diameter, and I need one in the 3" to 3 1/2" range.
(Also, I'm looking for a blade to use with the ZM attachment, which can accept small circular saw blades with a 10 mm aka 3/8 hole in the middle withOUT a mandrel).
Any other ideas? Thanks!
