Sander Recommendations?
Old 01-29-06, 08:31 PM
R
We are looking to do some kitchen remodel. This includes redoing the cabinets. We are going to sand them all down, taking the stain off completely, and then paint them. My question is...what would be the sander of choice to do this? Grit? My wife wants her kitchen redone...so basically, what new nifty tools should I buy?
Old 01-29-06, 09:08 PM
R
Would something like this do the work?
Bosch 1295D Random Orbital Sander
Old 01-29-06, 09:47 PM
Received 1 Vote on 1 Post
Depends on the surface Rap
It'd have to be pretty flat, no inside corners
That Bosch looks nice
For sanders I find I use a combination
For a 5" round I use a P-C R/O w/hook'n'loop
It's an adjustable speed, handle can go on either side long boy, can attach a vac, etc...
I like it a lot
I also use it for buffing (got the h'n'l pads for that too)
It's a little beefier than that Bosch
http://www.porter-cable.com/index.asp?e=547&p=2776
For a hand/palm sander, I use a 1/4 sheet P-C
http://www.porter-cable.com/index.asp?e=547&p=2780
The palm sander, being square, can get into place the bigger rounder one can't, so often I use both, and would be hard pressed to choose just one
...not that I'm saying you need two sanders mind you , but technically the big one is a sander, and the little one is a finish sander
Though if I had to, I think I'd have to stick with the 1/4 sheet palm
It's a good finish sander and can go places a round one can't
I can put some 34 grit on it and it doesn't blink
Straight up though, you're going to be bringing those pieces down to bare wood
For massive material removal like this, personally I'd whip out the lil' belt sander
http://www.makita.com/menu.php?pg=product_det&tag=9910
Not too big, not too loud
Hey we're not doing floors here...yet
Works nice
Then the 5" R/O to smooth and and maybe finish
That's if there's no need for the palm
Old 01-30-06, 05:52 AM
mango man's Avatar
have them stripped or strip them yourself rather than sanding the finish off
random orbit sander is my choice for best overall , but you might also look at detail sanders for finishing your cabinets
