Laminate trimmer as router? Or a router as router?
Received 0 Votes
I'm thinking of adding a router system to my ever growing manly love (not Brokeback love...manly love) of tools. I've heard of people using a laminate trimmer as a router, but why not just buy a router instead. I don't think I'd get into doing huge projects...but you never know. Can anyone shed some insight for me on this?
As you've noticed, most tools can be used for other things
If you have a laminate trimmer, it can be used as a router
If you have a framing saw, it can be used as a table saw
Should you buy a laminate trimmer to use as a router?
No
But if you had a LT and needed a little routing done....
I think you should go with the router(s), and if you need some laminate trimmed, get the laminate trimming bit for it
...or, if have a Roto-Zip, they have a laminate trimming bit for that too!
No
Received 0 Votes
I bought a small laminate trimmer and used it in place of a router. It worked good for me. But eventually I got a regular size router. Seems most of the jigs are made for the router not the laminate trimmer. I have the laminate trimmer fixed to my router table now and use it that way.
Get a router and use it to trim laminate. Unless you're making your living installing countertops, you can probably find other places to spend money than the laminate trimmer.
