Generator muffler
Old 02-26-06, 07:36 PM
Received 1 Vote on 1 Post
Generator muffler
Is there a way to make a 10 hp B&S generator engine quieter? Like a better muffler or muffler attachment?
Old 02-26-06, 09:27 PM
IBM5081's Avatar
Most generators are made quiet by placing them in a small doghouse-sized cover for a stationary installation. The exhaust can be directed into a buried barrel with a separate exhaust stack. Exhaust gases are most of the noise produced but not all of it.
Same thing applies to an air compressor.
Old 02-27-06, 04:22 AM
I've never heard of that but I like the plan. Can you provide more detail on the buried barrel (size and how much of the barrel is buried) and how the exhaust gets routed there?
Old 02-27-06, 05:16 AM
I
I've got the same engine on a portable generator and it's loud. I haven't used it much for the past couple years, but I've been planning to find a small car muffler to install on it - guess I haven't done it because I don't want to take the time if it doesn't work.
The barrel Idea sounds good for a stationary unit.
Old 02-27-06, 12:13 PM
Received 599 Votes on 532 Posts
I would be leary of installing an oversized muffler. I don't know for sure but would think that the added restriction might affect the way it runs. IMO the best way is to divert the exhaust [with pipe] further away thus directing most of the noise in a different direction.
Old 02-27-06, 03:19 PM
IBM5081's Avatar
You really do NOT want to put the weight of a muffler on the threads just outside the exhaust valve - too much weight. Put whatever muffling device - auto muffler, barrel in the ground, etc. on a separate support and connect the two with flexible metal exhaust pipe.
Old 02-27-06, 03:23 PM
IBM5081's Avatar
Here's a home-made (obviously) barrel muffler design: http://utterpower.com/muffler.htm
You would need to adapt the plumbing to the size of exhaust pipe that you have. It is a stationary-preferable solution.
Old 03-10-06, 06:01 PM
P
Received 1,460 Votes on 1,314 Posts
I put a car muffler on an 8hp generator about 10 years ago. The generator was extremely loud to begin with and the oversized muffler made little difference. There was a lot of noise coming from the intake (sound getting out through the carb.), and there was a lot of noise coming through the case (I assume valves clanking). Hopefully you will have better luck with a more modern engine.
Old 03-11-06, 05:29 AM
D
Generator noise
Should have bought a Honda inverter...
Old 03-11-06, 05:51 AM
IBM5081's Avatar
The Honda and Yamaha inverters seem to only come in the smaller sizes - 3500 watts seems to be the limit. I did observe a water-cooled Honda 6500 was much quieter and there are Hondas that are fully enclosed.
Old 03-12-06, 03:28 AM
. . . but pretty expensive.
