HELP...Sandblaster Recommendation????
Old 03-17-06, 11:13 AM
I want to buy a sandblaster and am having trouble deciding which one to get. This is for homeowner use. I know they take a lot of cfm to run so, I was hoping someone here might be able to recommend an efficient unit that wouldn't be cost prohibitive for this use. My compressor is rated at 9.9 scfm @ 90psi. I hope this is enough. Any ideas? Thanks, Joe in Texas.
Old 03-17-06, 05:32 PM
Received 672 Votes on 595 Posts
Check into the pressurized units, they are supposed to be a lot better than the small siphon units like the one I have. I used to use a commmercial type sandblaster and there is no comparison. Any air tool should have both a cfm and pressure requirement available before purchase.
