changing hacksaw blade
Received 0 Votes
Okay, I know this is probably a stupid question....
My husband had "opened" the hacksaw to change the blade, then got called away and didn't complete it. He had to leave town and now I am on my own for a few weeks.
So, I need the hacksaw for some projects and I can't seem to figure it out. I have got the new blade in place but it won't stay and the top part (opposite the blade) keeps coming apart as well.
Is there a piece I am missing? I have looked around and didn't see any more to it.
Any help?
Thanks,
Becki
Any help?
Thanks,
Becki
There are 2 types of hacksaws. On both the blade hooks the same. The most common type has a threaded adjustment on the hook nearest the handle - just turn until tight. The other kind has an adjustment on the top tube which basically does the same thing.
Becki: another thing to check is the hacksaw may use two different size blades, 10" and 12". The top rail slides and locks at one of two detents, depending on which size blade you use. Make sure the top rail is secured, install the blade on the two small hook like features and tighten up the take-up screw.
