compressor pump question?
Old 07-12-06, 04:21 AM
mrblue's Avatar
I have an old small vertical compressor. looks like someone has added dif. motor and pump... the pump is a 2 cyclinder , has w.r. morton ( or whorton) .. the tops of cyclinder has SPEEDY on it.. it is oilless.. i have found speedysprayer online and they seem to be for airbrushing or ? The compressor doesnt seem to put off much pressure.. i just wonder if that is all it is supposed to put off.. I does nothing like the other compressor i have about the same size.. thanks Don
Old 07-23-06, 06:24 AM
GregH's Avatar
Super Moderator
Received 62 Votes on 58 Posts
Don,
You can only know what capacity it has by looking up the specs for your particular unit.
The only Speedy compressors I am familiar with are a diaphram type and all have a very low cfm output.
I recently junked one and it was made to be a continuously running unit which means it was not meant to be connected to a pressure tank.
It would only put out around 50 psi which is all it was meant to do.
Perhaps someone unknowingly put this type of compressor on a tank.
