How to - Pegboard into Concrete
Received 0 Votes
OK, the time has come where I need to utilize the 10' x 4' of unused wall space in my utility room for some pegboard tool organization... My concern though is the unused space is all concrete (the divider between my townhouse and teh house next to mine, and the divider between the back of my house the the earth). How should I go about getting pegboard on my walls with the concrete backing.... Any help would be great. The only thing I came up with quickly is doing 2x4" at the top and bottom with adhesive on one side and concrete nails going into it, but not sure how well that would work. The pegboard could then be drilled into the 2x4"... What do you guys recommend....
Thanks so much
Thanks so much
Pegboard
Lumber applied to concrete should be treated. Rip treated 2x4 into 1" x 1.5" strips. Place on wall and drill through strip into wall with hammer drill usiing a bit of the correct size to install tapcon screws. Fasten strips to wall with tapcons. Then attach pegboard to strips.
