What charger for 7.2V cordless drill?
Old 08-05-06, 09:54 AM
H
I have a Ryobi HP721K cordless drill, and I have misplaced the AC charger/adapter. Replacement batteries are easy to find, but the adpaters are just about impossible.
There is a 12 volt battery charger available, part #7222701, that looks like the right one, but I don't know if that will work with a 7.2V drill.
Does anyone know?
Old 08-05-06, 10:32 AM
GregH's Avatar
Super Moderator
Received 65 Votes on 60 Posts
A charger that does not match the battery voltage cannot be used.
If you were able to insert the lower voltage battery it could explode.
Check to see however if it has a rating for lower voltage batteries.
The newer Makita chargers can do their 7.2, 9.7 and 12 volt batteries.
Old 08-05-06, 10:41 AM
mango man's Avatar
you can buy that drill new for 30.00 how much is just the charger ?
buy a new drill and then youhave two drills and extra battries .
have you talked to HD customer service ?
seems like they ought to be able to order it
or try here :ryobi service centers
http://www.ryobitools.com/service/service_centers
(call them and ask if the 12volt will work , on low volt items like this chargers often put out more than the stated voltage )
but I bet a new charger is 25.00
http://www.homedepot.com/prel80/HDUS.../pg_diy.jsp?BV
