Need Help for a craftsman 2 stage compressor problem
Received 0 Votes
I have a 7 hp. 2 stage craftsman compressor. ran into a problem with it, takes for ever to build up pressure. the compressor runs, it had started making a louder noise,like something broke??This is the second craftsmans compressor I have which did this. took the covers off, can't see much as it looks pretty simple,pistons are moving,must be some type of valves/ in the heads? not much to take apart,don't want to do any extra work which isn't neccessary. Maybe someone has run into this problem. what would it take to fix the compressor?Thanks in advance.
Look in the head for some reed valves. They are just strips of sheet metal and can crack or break.
Received 0 Votes
I Took The Heads Off Today,not Much That Could Go Wrong. There Is A Piece Of Metal Which Is Slightly Bent Up.i Ordered The Parts Today Plus Gaskets And Rings,should Fix The Pronlem.thanks For Getting With Me.
Received 0 Votes
My question to you my friend is where you ordered the parts from?? Craftsman wants to sell me the entire head/valve assembly when I believe replacing the three fingered metal reed valve will fix the problem. I would appreciate a pointing in the right direction. Thanks much!!
Received 0 Votes
Originally Posted by Panhead1
I have a single stage Craftsman compressor that exhibited your problem right down to the noise. Took the compressor head off and found one of the metal reed valves on the exhaust side had a broken chunk about half the normal size, and therefore my compressor would not pump above 60 psi.
