Circular Saw
Old 09-15-06, 06:15 AM
D
Circular Saw
I have a Circular Saw that looses power when under load; it this a sign of bad brushes or something else?
DWC
Old 09-15-06, 01:10 PM
IBM5081's Avatar
Worn brushes, undersized power cord, overloaded power circuit, dull blade, bearings damaged.
What are you cutting?
How old / how much use on the saw?
What materials can it cut without losing power?
Old 09-15-06, 02:47 PM
W
Received 51 Votes on 46 Posts
Circular Saw
If none of the above mentioned items work, check for a loose blade. This can have the same symptoms as losing power.
Old 09-15-06, 03:39 PM
chandler's Avatar
Received 9 Votes on 8 Posts
I have found, too, when sawing harder woods to spray the blade with Liquid Wrench Teflon dry spray. It really dries so there is no residue on the wood and it lasts a while.
