Best tool to cut duct work
Old 02-27-07, 06:28 PM
I
Hello,
I need to cut a hole in my duct work to add a vent and I am wondering if anyone has any recommendations on what kind of tools would work best?
Thanks,
Irishmen
Old 02-27-07, 08:31 PM
Q
Duct Cutter
Irishmen,
What type of ductwork are you cutting? If it's the standard, garden variety galvanized steel, it's hard to beat a quality pair of aviation snips:
http://www.mcmaster.com/ page 2264.
Less than twenty bucks and quite good at what they do.
Old 02-27-07, 09:44 PM
Ed Imeduc's Avatar
Wink
like said: A quality pair of aviation snips:. After you lay out the hole to start it .Use a screwdriver at a 45o to cut the duct . Tap the edge with a hammer to cut a slot across part of the hole then use the snips.
Old 02-28-07, 10:41 AM
daswede's Avatar
Iv'e used a "roto-zip" tool
Old 02-28-07, 02:56 PM
GregH's Avatar
Super Moderator
Received 52 Votes on 48 Posts
Snips are pretty much the standard way of dealing with tin.
I find that aviation offset snips that place the handle slightly higher off the surface are a bit easier to control than regular ones.
One way of starting the cut is to drill a series of small holes inside of the waste piece as a place to start.
http://www.doityourself.com/invt/6869457
Old 02-28-07, 04:23 PM
XSleeper's Avatar
Received 903 Votes on 829 Posts
I'm with GregH. I have a pair of 9" Prosnip Right Offset snips that work great for keeping your hand away from the sharp edge as you're cutting, because your hand is a bit higher than with normal straight, left or right snips.
The offset is the key. IMO, Prosnips are better than Wiss.
Old 02-28-07, 06:15 PM
GregH's Avatar
Super Moderator
I'll have to look for Prosnips................not a well known brand around here.
They are worth a try but a new pair of Wiss that gets an occasional shot of WD-40 cut like scissors through paper.
Old 02-28-07, 06:32 PM
XSleeper's Avatar
There's the problem. I let my Wiss snips sit in the rain one too many times.
I looked at the Wiss offset snips today and noticed that while the head is offset, the handles are still straight. The Prosnips pair that I have have a offset head AND a slightly curved handle that gets your knuckles farther away from the workpiece. So that's another bonus.
Old 03-06-07, 05:46 PM
nothing better than a screwdriver and a hammer
I watched a tin knocker install a new carrier oil burner for me and was amazed how quickly he cut out a rectangle with a hammer and a screwdriver. Red and green offset Wiss snips were the ticket for circular cuts. I love watching guys that are pros do their thing. One thing I do know that sharp edges on ductwork cause hands to bleed pretty fast if not careful. JB
