Craftsman Air compressor Bad motor
Old 11-20-07, 11:29 AM
W
I have a craftsman air compressor that blows the circut in the electrical panel. I have by-passed the switch and wired the motor directly. One I plug it in, it runs for 3-5 sec and blows circut. I have tried in many outlets and even in the shop they are all deticated 30amp outlets. It worked fine when it was put into the shed and about 3-4 monthes later it would not work. It is a Craftsman model 919.167340, 1 1/2hp A.O. Smith motor with piston attached. I have contacted A.O Smith they told me to go to Sears, after explaining they found out it was made for Devirbiss Air. I called them they told me to call A.O. Smith. So the cicle and finger pointing started. I looked on Sears website and the motor/pump is $200.00. On sale new they range about $300.00. I was hopeing to fix myself. Any ideas.
Old 11-20-07, 03:35 PM
GregH's Avatar
Super Moderator
Received 52 Votes on 48 Posts
If the motor is burnt you will at least need a motor shop to give you an estimate on repairing it.
Honestly, this type of compressor is made to be disposable and if you are considering replacing it do so with an oil filled, belt drive unit with a cast iron pump.
A unit like this in home use could last nearly a lifetime is used lightly.
Check the sticky at the top of this forum and a couple of previous posts on compressors.
Old 11-20-07, 03:39 PM
Received 98 Votes on 86 Posts
I'm with Greg, I think I'd replace instead of repair.
Old 11-20-07, 03:52 PM
Received 326 Votes on 281 Posts
30 amp outlets in your shop. I hope these don't have normal duplex receptacles on them. That would be a code violation. Maximum circuit for a duplex receptacles is 20 amps.
Old 11-20-07, 03:59 PM
E
Motors will do that (draw excessive current) when they are old and tired.
And cheap ones will do this rather quickly...
But, what is a consumer to do ??
Old 11-21-07, 05:44 AM
I had this happen to me last year. I had an electric motor repair shop nearby repair/refurbish the motor. It cost me $71. It has been fine ever since with more power than it ever had. I think you can also buy a new motor directly from devilbess. They are very easy to deal with -- much easier than sears.
Old 11-21-07, 05:53 AM
W
Thanks for the info. I kind of figured it would have to go and get repair at a shop. Just thought I'd ask to see if it could have been something that was easly handled myself.
JoeD the shop is a Mececdes repair center so all is up to code. No problems there.
jllcredce I tried to to purchase from Devirbiss and was told call A.O. Smith as they don't sell it.
Old 11-29-07, 03:12 AM
I
Many of the cheaper compressor manufactures use motors that have dual capacitors on them to make them start on smaller amp circuits.
If anything changes with these new overrated motors the system will not be able to keep up.
You might check the caps, relief valve that takes pressure off of the compressor when starting and the pressure switch contacts to make sure they are clean and not pitted.
Many of the non commercial home compressors are not worth putting too much work or money into.
Old 12-03-07, 08:07 AM
E
No truer words.
I wish I could find an old commercial compressor - these seem to last forever.... and people tend to keep them forever.
Old 12-03-07, 11:40 AM
W
Thanks, How do you tests the Caps. There are 2 on the top of the motor.
