hydraulic floor jack fluid
Received 0 Votes
I have a 20 y old sears floor jack. It raises a load but gradually drops w/or w/o a load. I have never added oil and it looks a bit low. Is oil the problem or is the pump likely bad?
Also, jack oil is pricey, and the manual says no motor oil, just jack oil. I have heard that brake fluid is bad, but I might be able to use ATF. Any recommendation on a substitute oil?
Received 0 Votes
Also, jack oil is priceyAll oil has increased in price by 50 to 100%.., and the manual says no motor oil, just jack oil. I have heard that brake fluid is bad, but I might be able to use ATF. Any recommendation on a substitute oil?
Rebuildable ??? This may be more costly than buying a new Chinese unit, BUT, quite possibly, your rebuilt may out last the cheap replacement..
I'd use jack oil, why take an un-necessary chance..
Always seek a consensus.
ATF is used as a hydraulic fluid in some applications but you have no way of knowing if it is compatible with your jack.
If not compatible it could damage the o rings and seals.
I have a collection of jacks of various types and my half bottle of jack oil has a thick coating of dust on it.
If you need that much oil that its cost is a concern it maybe time to replace the jack.
You should be able to buy jack oil [quart or pint] at most auto parts stores and some tool stores. I buy hydraulic fluid at tractor supply in a 2 gal jug - mostly for my tractor
I'd keep it full of oil and see how it does. If it leaks too much, I'd consider replacing jack.
