Replacement Durofix screwdriver charger
Old 04-16-08, 04:40 PM
B
I bought this durofix screwdriver
http://www.amazon.com/Durofix-RV332-.../dp/B00106E6DA
at costco a while back but now I cant find the charger and the screwdriver is not marked as to the input voltage or if tip is positive. Does anyone have one that can look at the output on their charger and let me know so I can get a replacement. Thanks
Old 05-22-08, 04:34 PM
B
Durofix 4v screwdriver
I have the same problem you do. I have a "universla" charger and can find the right tip but don't know the voltage setting or pos/neg tip. Hoipefully someone will see these and help.
Old 05-22-08, 07:51 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You can go to ebay and ask the guy who has this one for bid. I saw the pix, but can't quite make out the writing on the transformer. 350062321158
Old 06-04-08, 08:42 PM
D
I found my wall charger.
The center is positive (+) and the output is 6vdc@300mA
Old 06-04-08, 09:36 PM
B
Outstanding, thanks for the info.
Old 06-30-08, 12:55 PM
N
Replacement Charger
I find myself in the same situation in that I have lost my charger. Did you ever find a replacement? If so, where?
Thanks.
Old 07-01-08, 04:27 PM
B
I haven't done it yet but I am going to charge it with one of those multi volt adapters.
Old 07-16-08, 01:06 PM
K
How can you tell if the multi volt adapter will fit the durofix plug?
Old 07-16-08, 01:10 PM
B
The power adapter I have came with all the common plugs.
Old 07-16-08, 01:12 PM
K
I have a durofix rv332 I got at Lowes and it indicates that it is 4V 200min. Don't know if that means minimum amp or what. Nice tool, just wish I could find my charger!!!
Old 07-16-08, 01:18 PM
B
Just take it to radio shack and give them the info that dennyz provided and they will have what you need.
Old 09-16-08, 04:39 PM
C
Smile Durofix RV332 Charger
The info I have on my charger is as follows:
Plug in class 2 transformer
model no: D6300
input: 120vac 60Hz 9w
Output: 6Vdc 300mA
MFD 0648
(-)----(o----(+)
Made in China
I hope this helps.
Old 10-09-08, 12:11 AM
B
I never did find the charger that came with the screwdriver but I found my multi volt universal supply and set it for 6v tip + and it charged it fine.
Old 04-05-10, 11:21 PM
R
Charger info for Durofix RV332 4v cordless Li-ion Screwdriver
My charger for my Durofix RV332 4v cordless Li-ion Screwdriver says: Durofix plug in class 2 transformer, UL listed 69NO E97199 SA LR 68048, Model No: D6300; Input: 120Vac 60Hz 9W; Output: 6Vdc 300mA; MFD 0738
(the symbols at the bottom are a minus sign in a circle attached
by a line to a C with a solid dot inside it with a line to a circle with a plus sign in it)
