removing vinyl siding
Old 05-21-00, 08:05 PM
G
Guest
Post
I need to remove some vinyl siding without damaging. What tool would be used to do the unconnecting of panels?
Old 05-22-00, 04:24 AM
Post
You need a vinyl siding tool. About 6" long, with a special hook on the end. they cost about $2.50. You can get them at any home improvement store.
Old 05-26-00, 08:52 PM
G
Guest
Post
The tool is made by Malco. Model SRT-1. It is the best siding removal tool I've seen.
A mini wonder bar works in a pinch, as does a piece of siding turned upside down (use the same hook that you are trying to pry).
[This message has been edited by More than a Carpenter (edited May 26, 2000).]
