string trimmer
Old 08-30-00, 03:20 PM
Post
My trimmer quit working and when I took it apart, I found that the wires connecting to the inside end of one of the metal prongs was severed at the prong. Is there any way I can fix this?
Old 09-07-00, 03:23 PM
rpr3
Post
Hi --
It sounds like you've got an electric trimmer. If that's the case, you can probably re-strip the wire and re-solder it to the prong. But if you're not familiar with doing that kind of electrical work, it probably would be best to bring the trimmer in to a repair shop to have it done. Shouldn't cost much. Good Luck!
