Angle Grinder Recommendations
Old 06-20-08, 11:32 AM
Looking to purchase an angle grinder. Planning to use it to shape a paver walkway and various other home improvement stuff.
Old 06-20-08, 11:48 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Makita, Milwaukee, DeWalt
I've had a old Makita for years, cause I got a great close-out deal. But I've used the others and they all work pretty good. Look for a shield you can adjust without tools. Also good if they have a button style shaft lock. Go with a 4 1/2" Gives you a bit more depth of cut.
Old 06-21-08, 06:51 PM
T
Metabo is probably the best grinder on the market. I have Makita, DW, Milwaukee and a few others and still love the Metabo. It has a toolless blade nut which beats loosing the spanner wrenches like I do. It also has a great locking switch.
Jeremy
Old 06-21-08, 10:45 PM
C
A major plus on the Metabo is that it has a clutch which will slip if you jam the grinding wheel. That means it won't break your wrist while you fumble for the switch.
