drill problem
Old 08-30-08, 01:21 PM
C
drill problem
How do you fix a keyless drill chuck thats jammed? It will only open halfway so I get get any bigger bits in it.
Old 08-30-08, 02:07 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Mine had an issue like that. Make sure the screw holding the chuck on hasn't loosened up on ya.
Old 08-30-08, 05:09 PM
C
screws not loose. can't unscrew it either to remove the chuck. any suggestions to fixing it?
Old 08-30-08, 05:45 PM
mango man's Avatar
have you tried wd 40 ............................................
Old 08-31-08, 06:23 AM
C
Tried wd 40, still no luck
Old 08-31-08, 06:58 AM
Gunguy45's Avatar
Super Moderator
It may be shot. I finally wound up replacing one. Tried everything, tapping the jaws with a hammer, took it completely off, soaked in solvent, etc, etc. Finally chucked it in the vice and tightened it down til something snapped...lol, still jacked up.
Went and bought a new one for about $20 IIRC
