Kango needs parts
Kango needs parts
Hello i have a Kango Hammer drill, i use chisels and drill bits on it.
When i hold it downwards it works well....as soon as i lift it side ways or upside down it stops...i may need new brushs,......but can't find any anywhere, i need some help on a site that would sell them or parts for it....
model 950
ty
model 950
ty
Welcome to the forums! It is more than likely the cord where it enters the tool. Hold the tool until it quits, and with the trigger pulled, move the cord around. If it hits, then all you have to do is repair the cord by taking the case apart, removing the cord from its internal connections, cut it back, strip it down and insert the new ends into the connection area inside the handle. Then put it all back together.
