Mixing Rotozip and Dremel parts
New Member
Received 0 Votes
I had a Dremel with a bunch of cut off wheel and other stuff like that, mostly 1/8" shaft. I never really used the Dremel much, but while using it this weekend I burnt it out.
My friend is willing to give me one of his Rotozips since it will heelp with an upcoming project. I was wondering if I could safely use the Dremel parts with the Rotozip?
Agree with Goldstar on the rpm. Don't use the paper thin cut off wheels on a faster machine, and make sure you use well centered wheels, as an imbalanced one will make for a bad cut and can shake the thing apart. If it has a variable speed, always start off slow, anyway.
New Member
Received 0 Votes
I gave all my Glocks the 25cent trigger job by hand.
New Member
Received 0 Votes
Yeah, unfortunately LEO's seem to have the worst discipline and shooting skills of all the people I shoot with.
An easy to pass qualification held once or twice a year is the only requirement, which is pretty lame IMO. If using a firearm in public is part of your job, you should be required to train with it. What can you do...
Why do all my threads turn into Guntalk?
