Task Force 5-Ton Electric Log Splitter
Old 11-01-08, 03:56 PM
R
I purchased a Task Force 5-Ton Electric Log Splitter last fall and have use it satisfactorily. However, the ram failed when I tried to split a piece of wood with uneven ends. Lowes will not help me find a new piece. I also called the number in the parts catalog but have had no help there. Anyone out there got any ideas how I can get a new ram apparatus?
Dick in Montgomery, Texas
Old 11-03-08, 04:50 AM
W
Received 61 Upvotes on 53 Posts
Log Splitter
Is the ram a hydraulic cylinder? If so, try Northern Tool.
Old 11-03-08, 11:56 AM
What do you mean by failed? broke in two or just does not move? If it's stuck, you may have to bust it open and replace the piston bearings and packings (or have a hydraulic shop do it for you). If it's broken and in pieces - buy a new log splitter.
Before you do anything, check the flex coupling that connects the electric motor to the pump, make sure nothing is stripped there.
Old 11-03-08, 02:32 PM
R
It is and I will. Thanks for the heads-up.
Old 11-03-08, 02:38 PM
R
Actually the push rod bent. I had it welded but it then broke, probably because it wasn't welded properly. When I took it back to Lowes, they refused to send it back, help me find a new part, or give me the name of the manufacturer so I could try to find a new part myself. The part if labeled "push rod" but it is actually the piece the wood lays against as it is brought to the ram. All mechanized parts and the hydraulic parts also work fine. Just need a new push rod.
Old 12-06-10, 02:57 PM
D
you might try calling grassland equipment company 518-785-5841, Part # 520111 fits model 5005 i think that will work but first measure all of your hoses and motor mounts.
Old 03-12-11, 03:17 PM
R
Hey I'm new and trying to figure out methods of posting. I'll get there eventually. I'm posting as if it were a reply. Sorry.
I bought a used Task Force 5 ton electric splitter. Does anyone have a manual? Or the answer to a use question. It says to bleed the fluid before using. How do you check the level of the fluid in the reservoir? Only problem is how low it is to the ground. The splitter needs to be on a bench or something. Thanks, Ron Anything else I should know?
