snowblowers
Old 12-27-09, 08:00 PM
Post snowblowers
i have a craftman model #53688150. i broke the blade off of the housing at the bottom. i replacing the auger housing. i need to know how to get off the pulley wheel. i have taken off all the screws and the chute. it look likes the pulley wheel screws off the auger but it needs to be stationary to unscrew
Old 12-28-09, 07:24 AM
B
From picture on sears.com website, it looks like a smooth bore on the pulley. I likely is just pressed/slid onto the drive shaft. Is there a square slot in the pulley center? If so, the pulley is keyed (a small, rectangular piece of metal that keeps the pulley from rotating on the shaft) and needs to slide off. You may need to get a pulley/wheel puller. Try some penetrating oil where the pulley meets the shaft and gently try to tap around this spot with a hammer to loosen it up. You may be able to pull it off without a puller but only experience will tell. Good luck with it.
