Old SKIL Circular Saw Runs Backwards??
Received 0 Votes
I have an old SKIL Circular Saw I have dug out of my shed. Going to start some wood working projects.
I know this saw had a bad history of cutting really bad, so I went out and bought a new blade thinking that was the problem...
Installed it on the saw so that the teeth were facing clockwise. By my estimation, the saw should turn clockwise because, if it turned counter-clockwise, it would throw all the saw dust up into your face.
Lo' and behold, the saw blade DOES turn counter-clockwise. Which might explain why it cut really crappy..
My question is, what would cause this and how can I fix it?
Thanx
Michale
Thanx
Michale
Where are you looking at it from...and which side of the motor is the blade on.
Skilsaws cut UP though the workpiece...its just the nature of the beast. Nothing you can do. Tablesaws cut down through...but its just the way you feed the stock in....the motor still turns the same way.
Though I never had a problem with dust in my face...
Are all the guards and stuff in place?
These saws can face both ways, so CW and CCW can be confusing
They are intuitively backward in that they cut up from the bottom of the work, otherwise the saw would jump up out of the work
You will find your saw cuts much better with the blade facing the right way. Unfortunately, I can say this with much confidence and experience....
Received 0 Votes
Beer 4U2
Vic, oddly enough I do have a problem with my helpers changing my blade on my PC Mag423 left hand saw. They always think the label should be showing, but it is backwards!!
