compressor
Old 04-29-10, 08:55 AM
B
compressor
Is there any way yo quiet a compressor down with a muffler?
Old 04-29-10, 11:27 AM
G
A muffler where? The "exhaust" from the pump is the air being pushed into the tank.
Old 04-29-10, 12:03 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Not really...
You would need to put it in a sound deadening/reducing enclosure. You would still need openings for air flow and cooling.
Putting it outside while in use is an easy way to "move" the noise.
Old 04-29-10, 02:30 PM
Received 863 Upvotes on 755 Posts
Ya, the only way I know to reduce the noise of a running compressor is to put it in another room. My big compressor is installed in my tool room [8'x15'] even if the door to the shop [from that room] is open, it's not as loud as being in the same space.
Old 04-29-10, 03:06 PM
Received 1,273 Upvotes on 1,213 Posts
Yeah, put it far away and run extra air line to where you are
That or replace it with a quieter one, which is what I did with my first one - it was so noisy I would leave the garage when it cycled, man I hated that thing....
Old 04-29-10, 03:11 PM
Ya, I forgot about those extra noisy oil less compressors.... you might want to set those across the county line
