Does anyone make a fine-toothed keyhole saw?
Old 05-24-10, 06:49 AM
R
Received 2 Upvotes on 2 Posts
I often have a need for a keyhole saw that has very fine teeth and teeth that start near the tip. All of the keyhole saws I find have fairly coarse teeth. And the teeth start at a point where the blade is about 1/2 inch wide.
Does anyone make a good quality keyhole saw with fine teeth and teeth that start near the tip?
Old 05-24-10, 07:07 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
I've seen a push/jab/keyhole saw handle that would take reciprocating saw blades..do you think a recip saw blade might have the kind of profile you need? They make scroll blades that are only about 1/4" wide in 10/14/18 tooth..but they are only about 3 1/2" long. Bout 3/4 of the way down at this page...Milwaukee Sawzall Blades, Super Sawzall Blades
Old 05-24-10, 07:24 AM
R
Hey, Gunguy45, I think that will work. Do you know where you've seen the handle?
Thank you!
Old 05-24-10, 07:36 AM
Gunguy45's Avatar
Super Moderator
I did a quick search didn't see it...but I saw it at HD at one time...I'll keep checking.
Ahh shoulda checked there first....http://www.homedepot.com/Tools-Hardw...atalogId=10053
Also this...http://www.homedepot.com/Tools-Hardw...atalogId=10053
