ryobi laser miter saw ts1342L
the laser line was fading so i took it off to replace the batteries. after not being able to remove the batteries, i just decided to put it back together. the laser line was like new but it now needs to be adjusted because it is not lining up with the saw blade. HOW DO I REALLIGN IT?
Make sure it is completely seated against the blade and that the blade is up against the back washer/flange. Are there tiny allen screws on the laser washer?
Do you not have the manual?
I'll bet my Rigid is similar..but I can't get to the manual right now. I'll post later if you can't resolve it.
its flush and has a large allen screw in the middle which hold the entire unit in place. i have the manual and it doesnt tell me a damn thing. guess i'll call them tomorrow.
