air compressor oil level
Old 06-05-10, 02:34 PM
C
i have a fini air compressor which i havent used much. twice a year to spray glazes on my pottery. i just learned that it uses oil. how much do i add? Is it between the two rings on the dip stick? I also learned from a how to video that I am supposed to drain the tank. I have never done this and notice the tank has a small whole. Can it be repaired or replaced? tia.
Old 06-06-10, 05:41 AM
Tolyn Ironhand's Avatar
Received 896 Upvotes on 757 Posts
I am not familiar with that compressor but between the two rings sounds like it would be correct.
As for the hole, is it a leak or a T screw-like thing? If it is a leak, you will have to replace the tank as I doubt it can be repaired.
Old 06-13-10, 07:04 AM
rise2surge's Avatar
post a pic if u can
Celia,
my wife does pottery also, DONT fix the tank...post a pic and I'll see if I can see what it is and steer ya, oil in pottery glaze does some unpredictable things to the glaze final coat...
