Best saw for cutting thin wood?
Old 08-11-10, 06:37 AM
A
Question Best saw for cutting thin wood?
Hi,
I need to cut a 1" slit in the end of some thin pieces of wood (about 1/2" thickness). This would be going with the grain. What's the best type of hand saw for the job? I've tried a regular general purpose carpentry saw, but that's almost impossible to use.
I think the wood is poplar, if it matters.
Thanks.
Old 08-11-10, 06:57 AM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
A dovetail saw would probably work well or a backsaw.
Dovetail
Back
Old 08-11-10, 09:50 AM
W
Received 65 Upvotes on 56 Posts
Slits
Secure the wood in a vise or with clamps. Cut the slits with a jig saw using a fine toothed blade.
Old 08-11-10, 11:18 AM
the_tow_guy's Avatar
Received 259 Upvotes on 210 Posts
Could Dremel it too, maybe.
Old 08-11-10, 11:25 AM
mango man's Avatar
hacksaw would do it .................................................................................................................
Old 08-11-10, 11:35 AM
A
I'm ideally looking for a hand tool since I will probably need to purchase it and don't want to fork out the money right now for a power tool.
Old 08-11-10, 11:54 AM
Gunguy45's Avatar
Super Moderator
Any of those mentioned would work...though you didn't mention if you needed just a saw cut wide slit or something wider.
I recommended what I did as the stiff thin blades seem to be easier for me to make thin straight cuts. Plus, you can get them for about $10 or less.
Old 08-11-10, 12:12 PM
A
Just need it the width of the saw cut - no wider. It looks like the dovetail saws are pretty inexpensive. Hopefully it's something I can use for other projects.
Old 08-11-10, 04:30 PM
mickblock's Avatar
Received 1 Upvote on 1 Post
A general purpose carpentry saw should work. Perhaps it's dull or damaged?
Old 08-11-10, 05:43 PM
I have a Japanese-style "pull saw" with a thin, flexible blade and has two different edges. It takes a minute or two to learn to cut on a pull, but the cuts can be very clean and accurate if the material to be cut is held well.
I use it rarely, but it always does a great job for clean cuts when I get smart and use it. Originally bought for undercutting trim while installing laminated floor since the Fein "Multi Tool" was a little too pricey and does not need a cord.
Dick
Old 08-11-10, 06:01 PM
mango man's Avatar
Ive had one of the Japanese saws for a few years and
I like it a lot
