Campbell Hausfeld Airless Spray Gun Info Needed.
Old 09-07-10, 11:55 AM
I have a CH AL9415 3/4 hp .44 gpm airless sprayer. I need to get a new nozzle and tip for the gun. Typically all I paint is interior/exterior latex paint. My machine will not maintain pressure so I continually have to release the gun to let it build up pressure. I currently have a 517 tip in it and I am debating whether to go to a 415 or a 515 tip. Any advice will be appreciated.
Old 09-07-10, 01:54 PM
Received 850 Upvotes on 746 Posts
.44 gpm is pretty small. When it was new was it rated for a 5/17 tip? A 4/15 or 5/15 should help although it might also be an indication that the pump needs to be rebuilt. I don't know anything about the CH airless line but my Titans are fairly simple to rebuild. Do you have the parts manual that came with the airless?
Old 09-08-10, 05:50 AM
Actually last night I scapped the paint off the tip and was surprised to see that the tip was a 4/15. The unit was recently rebuilt so now I am thinking of going to a 4/13 tip.
On a second note, is there a concensus as to whether the paint should be cut with water? If so, how much water is added per gallon?
Thanks
Old 09-08-10, 09:34 AM
I rarely ever thin paint for airless spray BUT my airless is capable of spraying most coatings unthinned. Being a small unit, thinning the paint might help. Usually if you thin more than 10% you hurt the properties of the coating.
Have you checked all your filters? Generally there is a manifold filter [on the pump, near where the spray line attaches] and many guns have a filter in the housing - usually where the spray line attaches to the gun.
Old 09-15-10, 07:11 PM
B
You can get the information and parts you need direct from Campbell Hausfeld.
