Need Part- Ryobi 975r Ignition Coil 791-181067
Old 09-28-10, 08:03 PM
E
Found the ignition coil bad for the 975r Ryobi Trimmer. Can't find a replacement coil. Part number 791-181067. Does anyone have one, know where to find one? Any help would be appreciated.
Old 09-30-10, 05:03 PM
B
Old 10-04-10, 04:48 AM
I
I have in the past taken ignition coils assemblies apart. Separating the coil from the metal armature and just replacing the coil with a good coil of similar size from junk machine but not necessarily the same size assembly. Many times the coils are th same size just the armatures are different to fit different size flywheels.
This method works great if parts are really expensive or not available and of course if your as cheap as I am when it comes to fixing old equipment.
