Dust Collection System
I am preparing to setup a new dust collection system (to my new Delta Dust Collector). My question is regarding the best way to CONNECT the Schedule 20 PVC to the plastic blast gates and such. Do folks simply put them on and then seal them with duct tape, or screws and duck tape or ....??? there is a slight gap (maybe 1/32") difference between the diameter of the schedule 20 and the blast gates/connectors, and looking for best/common way to seal that up.
What is the best way???
Thanks -
Bubba
Thanks -
Bubba
Are you using the manufacturer's piping or schedule 20 off the rack? How do you plan on addressing static charge build up? Once you determine the proper pipe to install, use pvc primer and glue to fasten the pieces together. They should fit snugly, however, so be sure to check on what the manufacturer recommends.
i am planning on using Schedule 20 pvc pipe & wye's, and standard plastic blast gates.
I am planning on gluing the schedule 20 piping together with pvc glue.
However, I wouldn't think the pvc glue should be used with the plastic blast gates tho ...?????? (if i wasn't clear, that is where i'm unclear....) What is the best/common way to join the plastic blast gates and the pvc???
Bubba
Bubba
